Miner for AMD/NVIDIA 4G 6G 8G 10G GPU from Minerbabe
yes. i write my login email on minerbabe page and entered ip net mask and DNS also
try witthout ip and dns first.
Ok thanks. will try now
Any help please?
Shows no rig on minerbabe page
https://forum.grin.mw/t/miner-for-amd-nvidia-4g-6g-8g-10g-gpu-from-minerbabe/2184/258?u=rabinovitch
I had created group and its the DEFAULT, I had no problems with v 4.12, but this v 4.14 have this issue. thanks for replay.
anyone else having issues burning to USB the new 4.14?
No. My choice is 16GB USB 3.1
Is it just me or the minerbabe website/dashboard works VERY slow ?
Perhaps the servers can’t take the traffic ? Trying to export and flash some Bios files and I am constantly getting timeout errors and the refresh is really slow.
i have exact same problem on tb250 motherboard… looks like it cant establish network connection…
I tried also without ip and nettmask and dns but no success. I had no problem with 4.12 version. If you success please let me know and if i success i will let you know.
Why don’t you just use v12 ?
Hi, I resolved the problem by create a new account on minerbabe page. Now it work
that are great news… so something on minerbabe server side is blocking connection… i wish i know more about linux…
i think i found a problem
in minerbabe web manager, when You delete rig it is not deleted yet… it moves rig in ā€œdeletedā€ folder
i deleted it again and now it works fine…
I didnt deleted rigs. By try del and then re-del and rig online)
definitely works fine now…
but confusing fact is that ā€œlibegl warning dri2 failed to authenticateā€ window is still present…
but it is working, and i dont think i will think abot it anymore…
i play with vega watching core clock (SCLK) and its pinned directly to ā€œp stateā€ at p5 its ~1330mhz (0.42gps) core clock you set or voltage have no influence on ā€œrealā€ core clock , at ~1330 vega can run under 850mv on 1107 soc on win/ubuntu … so im asking about PPT suport ? they take a lot of power …
I would like more optimization for AMD and actual control over clocks. Other miners are close to 31 release so I’ll be jumping on them if this doesn’t get updated.
Core state 1 or 2? How? Screenshot please?
