Celko
January 29, 2019, 7:46pm
#1
With how much Grin a day you can expect if you mined with 2.2 gp
Celko
January 29, 2019, 7:49pm
#3
Besides, when mining with gringold miner only 30 percent of the gpu is used as I can increase it, use Windows 10 And how do I know if I’m mine with c31 or c29?
Hello @Celko ,
well… Pro Answer: Go for Linux… if you are using NVIDIA, just copy-paste my commands i posted here:
Hi Silver, follow exactly this commands:
cd ~
mkdir grin
cd grin
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-repo-ubuntu1804_10.0.130-1_amd64.deb
sudo apt-get install build-essential dkms
sudo dpkg -i cuda-repo-ubuntu1804_10.0.130-1_amd64.deb
sudo apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pub
sudo apt-get update
sudo apt-get install cuda-libraries-10-0
sudo reboot
cd grin
sudo apt-get…
If you are using AMD, go for an OS called MinerBabe, see more here:
[%E7%9F%BF%E5%AE%9Dlogo%E7%9A%84%E5%89%AF%E6%9C%AC]
A Grin GPU miner from Minerbabe
Minerbabe is a GPU mining OS base on Linux. Minerbabe supports many digital coins.
Today, Minerbabe releases a new miner to support Grin.
You can use AMD/NVIDIA GPUs with 4G/6G/8G/10G memory to mining Grin now!
The miner is optimized for GPUs with different memory.
The test results on some typical GPU are below:
Cuckaroo 29
GPU
GPS
AMD 380 4G/8G
1.17
AMD 560 4G/8G
0.81
AMD 390 4G/8G
1.52
AMD…
Take Care, have fun!
