Miner for AMD/NVIDIA 4G 6G 8G 10G GPU from Minerbabe
almost all rigs ded at the moment lol
I can’t boot minerbabe from USB.Just a black screen.I have gigabyte z270 k3 motherboard,maybe is that problem?
im using asus prime z270 a and working fine on 3 rigs
im using the asus z270 a prime and mine works fine, 3 different rigs
My screen,after BIOS update
What can i try?Still doesn’t work.
I have 6x1070ti with latest drivers.
Have you edited the miner to link it to your minerbabe.com log in credentials?
Due to this version of driver, you can only change the state and fan of VEGA. OC by set the state [0-7].
Thanks for reply. Strange thing is that it used to work until yesterday…
What about the dashboard errors which are happening since yesterday? (please see above lots of users confirming)
So we can’t use the overclocking feature and specify individually, we can only use states?
For Vega, it is yes.
My rig doesn’t appear on minerbabe site.
Have you created a group and assigned your rigs to it? You basically need to create groups/templates to tell the rig what to do. See link with tutourial: https://www.minerbabe.com/pc.html/#/helps/startDig
Sorry Jie, We can only use states for Vega. Correct?
Hello! Please quickly resolve the issue with the chipset z270. I have several rigs with Z270-Gaming k3 motherboards, all don’t work. With other chipsets I have no problems
Hi. Have you download link to minerbabe 4.14? Thanks
https://cdn3.minerbabe.com/disk/minerbabe_v4.14en.img.zip
vega use a lot of power heve you plans to add PPT suport for them ?
Thank you. I tray it, but no worker shows on minerbabe page. FAILED TO AUTHENTICATE. Please any help
Please try to set the core state to 1 or 2 to reduce the power
Did you set the account.txt?
