Problem is on SMOS and grin-miner.
Minerbabe reports correctly since last update, but cannot use the dashboard as of today, so it’s kind of unusable.
May be its 4.14 ver not correct working?
4.12 all last week was working correct
Well it sounds like you are getting rejected shares due to difficulty
Probably… but I do not know how to change difficulty in grin-miner.
@integy I use 4.12, did not upgrade to 4.14 yet
what changed with 4.14?
i only see changelog till 4.11
https://www.minerbabe.com/pc.html/#/helps/updateLog
https://www.minerbabe.com/pc.html/#/helps/commonDisk
Try download)
and
1st post UPPPP
Download minerbabe image: https://cdn3.minerbabe.com/disk/minerbabe_v4.12en.img.zip
Its old version
What does “abnormal” mean? I get red boxes quite frequently, then it red box disappears. Does rig restart? I dont want it to keep restarting and go back to mining, i want it to be stable and mine. Sometimes i am not even sure, if overclock settings are saved and applied.
If it says “Run” but no hash rate report under G0 G1 G2 … (i just see “-”). Does that mean that rig restarted itself and is trying to get online, or that minberbabe dashboard lost connection to machine or something else?
PRIVET,
is this red “abrnomal” because of network between minberabe dashboard and rig or something else? I cant figure it out.
I dont now. At f2pool rigs online
seems like something up with the pool like some pools reject low diff
i changed pool got rid of most abnormals
What pool did you go to? I got abnormals using grinmint.
frostypool… but then i choose verify difficulties which seems to help…
on grintmint you have to choose verify difficulties otherwise alot of work will be discarded
Been two weeks since the claim that kbminer Linux binary repo would be published.
Is today the day?
Thanks for the tip. Do you mind posting here or via PM you current overclock settings just so I can use as reference?
How do i verify difficulties on grinmint?
Any ETA for the image with RocM?
Seems the 4.14 img of minerbabe is available for download, is it possible to have a changelog (the site stopped changelog at 4.11).
Thanks
