Could you teach me how to implement a cron job to shutdown every 7:30 am on weekdays (monday to friday) only?
Hello! I already wrote above, downloaded the new version of Minerbabe 4.14, it also does not work with the chipset Z270. I have a few circuit boards motherboards Z270-Gaming k3, they all do not work. With other chipsets I have no problems. Can you solve this problem? Jie, my mail vitaly11091977@mail.ru
Solve this problem please
4.14, how? It’s not the last version, if you press red button on the official site “minerbabe.img.zip”, will be downloaded v4.15.
v4.15 with the chipset Z270 work?
In my case even on v4.12 gigabyte z270p-d3 worked well, about v4.15 i don’t know, but interesting why you’re didn’t download last version from official site, and where you’re download v4.14 thinking it’s should be the last?
Is there a way to upgrade to the latest minerbabe without refreshing the USB. Automatic?
Not working and 4.15 on the motherboard boards Z270-Gaming k3, unsubscribe pliz in lichku who managed in this Board to run
when you enable do not burn indicators LAN port. the Internet is connected through a cable
the ’ net. nearby there are Riga on other motherboards are working fine))
My mail vitaly11091977@mail.ru
Try to use any other Ethernet athapter than built-in on your motherboard. TP-LINK UE200 is working with all Minerbabe versions.
PCIe-x1 все заняты рейзерами, остается только USB и то если прокатит
Вы такой пробовали у себя?
Рабинович написал про TP-LINK UE200, а он то как раз и есть USB).
Спасибо, уже заказал. приедут попробую
how to set up a bminer on minerbabe to the f2pool (Grin)? The miner is work, but on f2pool is empty. how write username and worker?
what? bminer is a great miner, however this is miner babe Im confused to your questions as they are different miners. to run miner babe u flash a usb drive then put it into ur motherboard and boot from the drive, when it starts working it registers that rigs IP on ur minerbabe url Dashboard (on a different machine). I personally think minerbabe is not worth it.
The Minerbabe has a built-in bminer. But it does not work.
So just migrate to HiveOS, for example (free if you run it on less than 4 rigs). Or to MinerMonitoring OS (2$ per instance per month).
I did get minerbabe to boot - it was my usb drive must have had a bad bock - if you see a usb cable problem error you probably have a super block issue on your usb drive. However, trying to mine grin using c29 or c32 it won’t connect to grinmint - login problems. I believe my wallet info etc is correct. The same rig works fine on its ssd mining config so don’t think it’s the network - also mining grin to grinmint.
Also apparently minerbabe is the only option for mining c31 with vegas
