Miner for AMD/NVIDIA 4G 6G 8G 10G GPU from Minerbabe
Where is this Verify Difficulites option? I calculated I’m losing 50% of my hashes… Getting less than 2 Grin daily.
In the group configuration pannel, where you could choose the 0.7.0 version.
However, even you did not use the option, you should not loose GPS so much.
Hello fellows, I’m new to that MinerBabe OS, can we use the kbminer for grin under other ubuntu distros ?
Dev, will you add option to run 2 miners at same time, for rigs with mixed cards?
Like you can in windows or hive.
For example on one rig 3x gtx1070 mine c31, and on same rig 3x gtx1060 to mine beam…
For now it is no possible in minerbabe
how the hell can you ssh into the rig?
and why the fuck the os come with a pre-loaded ssh key?
Anybody experiencing “Abnormal” reporting in dashboard but rigs are working ok on pool?
same for me. it lasts for few minutes, than ok, but shows again…
yes, definitely something has changed in the last few hours.
Also I cannot overclock the Vega cards… only option I see in that window is to change the State and Fan, no core/mem clock or voltage
Yes. Also temp limit does not work. i have limit to 70, and just saw one of my cards at 84, and also power limit is messed up on that card. Strange
@jie Please update us regarding these issues… dashboard is a mess
Thx
i am also getting Abnormal message while logging on miner is good and poolside also
this started yesterday late i guess, i was getting alot of abnormals started tons of times
@jie, thanks, I see the verify difficulties…
Any chance having xmr-stak-amd on it?
Hello. I’m currently trying out the Minerbabe OS with my AMD Vega rig. I like the software and the dashboard so far, so congratulations for that. I have two questions though:
  1. On the terminal screen, is there a way to remove the “screen timeout”? I don’t want the monitor to turn off after a few minutes.
  2. I have 6 Vegas. When mining the C31 algorithm they all show a hashrate about 0.42 gps, but one specific Vega 64 is going up to 0.36 and doesn’t seem to go higher than that. What could be the reason? If someone else here wants to share their overclock settings I’m all ears.
Thanks.
I have Abnormal all day today!
It is changing from one to anohe rerigs
Yes I am disappointed to report the graphrate from minerbabe has been unstable over the last few days. If this continues I will have to switch miners. I’m mining on c31 and have tried the latest release as well as 0.0.4. It was stable for a while but not anymore :frowning: @jie have you noticed any issues from your end? The dashboard nor my pool report the stable gps that was working for over a week. Have tried multiple pools and rigs, the issue seems to be with minerbabe.
yeah man hard to keep track if miners are running or not, dont know whats happening, maybe some API trippin
Anybody runs c31 on grin-miner on SMOS?
I am getting 1.7gps for 3x1080ti but on grinmint I have only 1.2gps accepted.
Since minerbabe has issues I am considering again to switch to grin-miner if I can resolve this
Had the same issue. Individually change the overclock settings. One of them had trippy stuff going on for me.
I tryde today SMOS and grin-miner. But I have 1080 and I recieved very little hashrate
cuckatoo_mean_cuda_gtx_31 @ didn work
cuckatoo_lean_cuda_31 @ 0.36 from 6x1080
ocl_cuckatoo @ 0.35-0.36 from 6x1080
its not normal
Have you waited for 24 hour average and tried activating difficulty request setting on minerbabe?
