Miner for AMD/NVIDIA 4G 6G 8G 10G GPU from Minerbabe
z270 motherboard is not supported.We will be compatible later.
Ok, thats mb is used by many miners hope you can support it soon. Thank you
use kbminer v0.7.0, it will verify difficulty.
I am using kbminer 0.7.0 and I am still getting rejected shares due to low difficulty on all my machines ( different setups - but all using RX80s ).
BTW - my main PC ( which has 2 x RX580 installed ) - has a Z270 mainboard and apart from the rejected shares issue, everything else works fine. I have tried mining ETH and everything is perfect on ETH.
is there a way to set a rig id as worker i am mining grin and the pool is like username.workerid and password x but now i am mining on the pool with unknown workerid… userly there must be a way like username.%id%? or is such feature not there yet?
use “Verify Difficulties” option in the group config pannel, maybe need press CTRL-F5 to refresh the page in your browser.
Please tell me what is the pool, we will adapt it .
Frostypool (https://grin.frostypool.com)
When can we expect it? (also can’t this be doen with prefix or postfix?)
Hi all, does this work on z77 or z170 mb’s ? its a long drive for me to try it myself sadly…all my rigs here have asus z270 a-pro and it does not want to boot, or it does then goes to a black screen with solid cursor. Thanks for any advice
Same here :frowning: no solution offered by minerbabe atm
I will play with bios settings and usb ports/sticks for a while to see if i can get it working…if i have any luck i will update this thread.
Ok thank you, i hope you can find something :slight_smile:
No worries, i read somewhere that you can mine c31 on smos but i can’t configure it to do it:sob: i never used it before so learning…you might have more luck than me, if you do try and get it working let me know please:fist_right:
yes got it works like this but results are not so good
Thanks so much for that…if i can’t get minerbabe to work i will try smos again now.
i read this for the frostypool:
Minerbabe i see
Minerbabe banned, use bminer or grinminer
Minerbabe send low difficult hashes
Today server dont receive low diff hashes
Accept, but dont write in database
is there way to put in difficulty to optimize pool experiences?
the above comment someone wrote on my on Discord
Hi - seems to be working now … sort of :slight_smile:
What is the error : “ignore solution due to low difficutly” ?
@jie Hi! Can you please check “Watcher set” option on dashboard? I have set it to “ON” but it does not reboot an “Abnormal” rig.
Thx
Use the option “Verify Difficulties” according to your pool’s need.
It’s just a log information. Please ignore it.
