that’s pretty cool, seems the gps is 2 times higher than 2080 Ti.
yes, but no shares submitted, means no actual solutions found!
Seems a bit slower than a 1080 Ti at just under 0.5 gps…
You should see some solutions with
./cuda31.1 -r 4 -n 98
Quadro P6000 with 24449MB @ 384 bits x 4513MHz
Looking for 42-cycle on cuckatoo31("",98-101) with 50% edges, 64*64 buckets, 176 trims, and 64 thread blocks.
Using 12800MB of global memory.
nonce 98 k0 k1 k2 k3 18a95d32908bf749 23c395cae77ea9b2 38c2aae4fed971a2 167504e8f5256d1f
Seeding completed in 150 + 263 ms
12-cycle found
14-cycle found
176 trims 2261 ms 264438 edges 81 ms total 2342 ms
Time: 2342 ms
nonce 99 k0 k1 k2 k3 8785f61f3e087286 91b57e6072a0cdaa 8035f9ee251a77a0 de03da786148f07
Seeding completed in 119 + 229 ms
2-cycle found
8-cycle found
42-cycle found
28-cycle found
10-cycle found
176 trims 2194 ms 259691 edges 264 ms total 2458 ms
Time: 2459 ms
Solution 1128e07 c181131 110fad36 1135ddee 1669c7d3 1931e6ea 1c0005f3 1dd6ecca 1e29ce7e 209736fc 2692bf1a 27b85aa9 29bb7693 2dc2a047 2e28650a 2f381195 350eb3f9 3beed728 3e861cbc 41448cc1 41f08f6d 42fbc48a 4383ab31 4389c61f 4540a5ce 49a17405 50372ded 512f0db0 588b6288 5a36aa46 5c29e1fe 6118ab16 634705b5 6633d190 6683782f 6728b6e1 67adfb45 68ae2306 6d60f5e1 78af3c4f 7dde51ab 7faced21
Verified with cyclehash c11f1f37a807ac29dafbdb606f97192c8f659797d23b3b3ad4ce16687cdc690e
nonce 100 k0 k1 k2 k3 37c90afb5d1a6592 af620b0603eddc8e 466cad8f3d4a7921 dd302e450b02d0da
Seeding completed in 118 + 226 ms
6-cycle found
176 trims 2189 ms 266183 edges 75 ms total 2264 ms
Time: 2264 ms
nonce 101 k0 k1 k2 k3 8a4f6f8a89edbb1f f2f46cc15c61a4b6 91e7685f67db1a4f c3b01b70b6da7dc9
2-cycle found
6-cycle found
42-cycle found
176 trims 2190 ms 270900 edges 273 ms total 2463 ms
Time: 2464 ms
Solution 1117366 1276469 7ed59bd d9c3b71 10020c7c 11cda347 171f5ae0 18e3d06d 190251e1 27287fa4 274930cf 28df0066 2b914e8d 2c43a962 2de60e4e 330e6b5e 3328f706 342ba4cc 355f2735 38c23873 3e28dae0 42c92723 4a6a8217 4b38de80 4df443d2 4eb017df 4ec8cac5 4f1c69ba 4fed1dc0 53086766 57b16a33 5a349505 61229903 614f201b 67167d88 6a02f3a4 6b19907f 6bdc93d6 6c5b7fc1 71a30884 74740da0 7c7f241c
Verified with cyclehash 1d131e51e224dfcfbf3bba33e1e857f4cf7cd491f8913fe85a505a59594c9341
2 total solutions
yes, increasing the number of nonces increases the chances of finding solutions and it did find 2…
but I do get that using the GTX plugin… ~0.5 GPS…
my doubt was with this figure of 3 GPS using the RTX plugin…
(AND, now a figure in the thousands of GPS, when it gives me a specific memory error… happened to me twice)
Using the rtx plugin on anything other than a Turing architecture will not work and produce bogus results…
getting 21.2 GPS on ten 2080Ti card now with bminer
Is it stable? How many rejected shares?
Interesting, are you runnin Bminer on Unix ? WIndows underreports memory by 3,1 GB on 2080Ti …
yes on ubuntu 18.04 system
on what cpu ?
bminer seems use a lot of cpu usage. it’s affected the hash speed.
using some server Version cpu now, E5 2620 now
on C31 algorithm, not C29 algorithm. C29 should have 10 GPS
Yes, 10.46 is my AVG for 2080Ti on Windows.
What screws GRIN up for me personallz is that supporting grinmint as a pool with expensive 2080Tis is a waste because I get around 0.3 GPS reported hashrate there, whereas f2pool gets me 1.5 GPS for C31.
What is to blame ?
