in grin-miner, the only difference is to choose the “right” plugin.
another option to start the miner is to invoke your start script from cron
add the following line in your user’s crontab @reboot $HOME/startmining.sh
the grin-miner start script can look like this (i’ve used tmux instead of screen)
$ cat $HOME/startmining.sh
#!/bin/bash
tmux new-session -d -n mining
tmux send-keys -t mining “cd $HOME/grin-miner” C-m
tmux send-keys -t mining “./grin-miner” C-m
dude i don’t get this it is almost 2 am and i am loosing my mind…
i set up everything so far with all the necessary upgrades, drivers
miner is working and it shows the rtx 2080ti but status is errored
i suppose it is because the gui is not turned off
has anyone a video tutorial where i can see how to start the miner without the gui on linux 18.04 please?
II’m afraid there is no such kind of video. The steps I described in my previous message are easy to repeat, please try it.
Open a terminal in your Ubuntu, perform a ‘sudo systemctl set-default multi-user.target’ command and reboot. All you need after that (but you can do it in advance) is to configure your .toml file. Here is my example:
okay thanks mate will try after work today
can i not just put plug the monitor in the vga on-board card adapter and try it to run it from there if this does not work for some reason?
Hi guys,
I’m getting the strange figure of 3 GPS (C31) from an NVIDIA P6000 (has 24GB ram), but no shares submitted, and if I try to run 2 instances of the CUDA plugin, it says ‘out of memory’, but if try openCL it runs (slowly, but does run).
Any ideas?
Quadro P6000 with 24449MB @ 384 bits x 4513MHz
Looking for 42-cycle on cuckatoo31("",0-3) with 50% edges, 64*64 buckets, 176 trims, and 64 thread blocks.
Using 10928MB of global memory.
nonce 0 k0 k1 k2 k3 a34c6a2bdaa03a14 d736650ae53eee9e 9a22f05e3bffed5e b8d55478fa3a606d
Seeding completed in 130 + 244 ms
4-cycle found
6-cycle found
12-cycle found
18-cycle found
176 trims 2220 ms 270141 edges 103 ms total 2323 ms
Time: 2323 ms
nonce 1 k0 k1 k2 k3 be6c0ae25622e409 ede28d78411671d4 74ffaa51c7aa70ac 2ab552193088c87a
Seeding completed in 116 + 228 ms
176 trims 2189 ms 277821 edges 85 ms total 2274 ms
Time: 2274 ms
nonce 2 k0 k1 k2 k3 543485efe8555e24 2d56d531df445967 821a4361f6f57e4 2eefbb55f1490553
20-cycle found
176 trims 2175 ms 276573 edges 67 ms total 2242 ms
Time: 2243 ms
nonce 3 k0 k1 k2 k3 5d869ae27494696c cbd3d38a013269 ba7c8d12fef80ffc 955b4761ba671c90
Seeding completed in 115 + 227 ms
2-cycle found
2-cycle found
28-cycle found
176 trims 2171 ms 268920 edges 98 ms total 2269 ms
Time: 2270 ms
0 total solutions
