2080ti - Best grin miner?
Hi folks, I have a rig with multiple 2080ti GPUs, mildly overclocked. I’m getting about 2.60 gps per GPU using bminer 15.8.7 (c31) on Simple Mining OS, and I use sparkpool.
Anybody getting better gps? What miner and pool should I be trying, and why? Thanks!
can you share how you overclocked? Windows? Linux, tks…
I use simple miner OS, not windows. core +150, memory +400, 190w power limit.
Gminer is currently the best performing miner program:
gps
Results from this rig:
Wow, the temperature is really good, do you have an air conditioner?
Are those power figures accurate? I thought TDP for 2080ti is 250w?
In my setup, each GPU is maxed at 190W. I’m water cooled, temps are 40-50C over 7 GPUs…
The manufacturer claims these are capable of over 520W per card (assuming 100% or greater power limit + 100% load) because each card is powered by 3 (three) 8-pins.
Runs cooler than typical water-cooled Hybrids because of x2 radiator size, x2 radiator fans, & large copper heatsink (runs the full length of the PCB):
interesting. you are getting 2.94 G/s at 360W. I’m getting 2.6 G/s at 190W. Based on Whattomine.com, my rig is about 14% more profitable?
You asked if someone was getting better gps using 2080 Ti on c31 and I obliged. I can’t recommend the cards I’m using if one’s primary concern was being economical & frugal, but if you want the highest gps and most coins, then there’s no better option.
In regards to the question in your thread title, the best performing for memory intensive c31 should be the 24GB Titan RTX, if best is based on hash/watt with cost of hardware not being a concern.
Currently, that would be Gminer, if you want the highest hash and stability on both c29 and c31.
Grinmint is the community’s pool of choice.
  • Trust. Is run by Grin dev: quentinlesceller
  • 0.5% goes to the Grin Developer Fund -see contributions
  • Fastest payout (coins mature in 12 hrs) with lowest minimum withdrawal requirement.
  • Payout by your choice of file or http (instant).
  • Provides handy stats, charts, and calculator.
Got it. In hindsight it was a bad question; higher gps isn’t necessarily better if it takes 2x the power.
Have you tried optimizing your power to see how low you can go without sacrificing hash? I wonder if you get the same at, say, 200W? or is there something inherent with Gminer that requires that much power compared to Bminer? Are there any studies/comparisons with real data that show that Gminer is better than Bminer, other than anecdotal?
Sure, I could just say I’m getting about 2.6 gps @ 190W, or I could provide quasi-proof, by capturing at the most favorable hash/watt fluctuation (lets be real, power use can fluctuate by 50W+/card with hash remaining relatively unchanged). Regardless, our goals are very different; I prefer more coins. I’m not cutting corners on any of the hardware, nor am I cutting corners on optimizing for best hash while remaining stable, especially not during winter, when our rigs can be pushed harder yet remain cooler.
How do I know that Gminer is currently the best performing miner program for Grin (both c29 & c31)? From XP (experience). I fiddle with a lot of rigs/cards/configs. But don’t take my word for it, you could run Gminer and see the results for yourself. Or don’t, that’s totally your prerogative, just as lowering the power limit on my cards is mine.
Awesome Miner web view:
Awesome Miner desktop view:
It’s only 1 card running hot, a RTX 2080 FE currently at 87C:
yes, different goals. You prefer more coins. I prefer more profit. Thanks for the screenshots, nothing helpful there though.
So since you are focused on more coins, can you share how many coins/day you are getting from the rig you posted 2 days ago? 6 2080ti GPUs? A screenshot of THAT would be helpful.
Got it, you’re chasing the daily USD, cashing out to pay utilities perhaps (hence the penny pinching), and you’re obviously not in it for coin accumulation. I’ve been mining for years (filling bags) and have never sold anything (never cashed out) and see no reason why I would any year soon. I favor lower SAT for Grin for lower difficulty. You’d favor less coins if that meant more USD. I’m looking to the future, not so much the now.
I have everything pointed at Grinmint so my coins earned per day are the result of all cards and not just the K|NGP|Ns. However, if you take the hash from x6 2080 Ti K|NGP|N = 17.65 gps…
gps
…then plug 17.65 into the pool’s calculator for the c31 field, you can see estimated results:
-source: https://grinmint.com/calculator.html
thanks, I’ve seen the calculators… however, I found that they aren’t accurate enough to base decisions on. Seems like there are a lot of variables that can affect the number of coins/day a rig can mine (perhaps the pool, the miner/OS, fidelity, etc.). There could even be error in the fidelity and hash speed that a miner displays.
The be all, end all, comparison is coins/day I guess.
While our hash remains relatively constant, the smaller pools experience significant variance between daily earnings because of pool luck (how many blocks found), so judging a pool based on 1 day’s earnings is inconclusive. When I was on MWGrinPool, one day may be 1 block total found for the day, and next day could have 15 blocks found, a 1,500% difference between daily earnings. Grinmint is medium sized so it still has some notable variance between daily earnings. Here’s a great source for comparison of daily earnings among the largest Grin pools:
https://grinmint.com/profitability-charts.html
