Hello, I started low throughput mining (two miners at 0.08 each) within minutes since main-net went live.
I have been doing git-pull/recompile a few times a week to make sure I am on latest version of the software.
I have mined zero sofar (today is feb 7th).
Is there a way for me to validate that my setup is actually correct, and if I mine something it will be added to my wallet?
sofar my wallet is 0 for everything. And two miner instances say that I have found 0 blocks.
I have used the calculation mentioned on this thread
to figure out how long it will take me to mine a coin
(0.08*2) / 222675
(my gps) / network hash rate.
it is coming up with
1.8 / (10,000,000)
coins per day.
so that means, with my rate, will mine 1 coin in about 5 million days
Does the above sound normal? (for some reason I thought that mining on non-specialized hardware would be feasible)
Or could there be something wrong with my setup.
(the actual instances are running in Hyper-V VMs on Xeon E5-1650 @ 3.2 Ghz)
I am running cuckaroo_cpu_compat_29
with nthreads = 8
all other options are default
