I have applied some OC settings, how do revert back to default?
Why not to simply set the overclocking to “Default”?
Yea found it under rigs and i clicked on the rig, then upper banner, overclock then the window of your screenshot appears. Thanks man.
hello to all guys, sorry my english but i’m italian and i’m using google translator. I tried with my 4gb RX 480. the operating system the law but I can not find the internet connection, when I start I am written an error message, how can I solve this problem? my motherboard and H370M DS3H.
I hope someone can help me
Hello! Who can tell what the optimal settings for maps gtx 1070 and gtx 1080
Hello! Can you please add Bminer v.12.2.0 to Minerbabe OS - it’s most profitable for mining GRIN c29 on RTX cards! Thanks
Hello! Trying to start my rig on Minerbabe with f2pool but it says try to log in:
But there’s no option to input my login to pool name. Only pool name.Could you help me please find a way to connecting? Thanks
In the “Group” for your rig you will have assigned it a “Wallet”. Make sure the address you have input for the wallet you are using for the group matches the username to your pool.
Thanx a lot. I found it
Any thoughts about my situation? 1080Ti on C31. The other 1080ti and 1070 work well. 16GB, FX-8350. I’ve tried also version 0.0.5
level=warning msg=“[Device: 0] Run error: Device 0 GPUassert: out of memory mean.cu 434”
All 3 GPUs work perfect when switching to C29 in Minerbabe.
Try again, maybe under v4.11. It (kbminer 0.0.5) helped in my case.
Hi,
I’ve two questions.
- I want to use my buildin Wi-Fi adapter, but I guess I need to have a root password to install proper software?
- On my RX 480 I have a message, that only 4048 MB of 8GB available in kbminer - how to fix?
@jie Hi! Is there any possibility to display CPU type in minerbabe dashboard?
And also CPU utilization?
Looks like grin mining is using a lot of CPU on rigs with multiple GPUs
When mining on GrinMint c29 or c31, all I get is rejected shares. Using latest kbminer. I can mine on MWGrinpool and Luxor with no problems. I have RX 480’s
time=“2019-01-25T16:07:32+08:00” level=info msg=“found share on device 5”
time=“2019-01-25T16:07:32+08:00” level=warning msg=“share rejected: [-32501]Share rejected due to low difficulty”
Why does this happen?
Hello.
Im mining c31 with minerbabeOS
rig1 6x 1080ti gamingX , i7 gives me around 0.5 per card
rig2 6x 1080ti gamingX, celeron g1830, gives me around 0.42 per card
rig3 6x 1080ti aorus, celeron g1830, gives me around 0.42 per card
Got question.
I’m using same oc settings, Is the cpu bottleneck ?
Very very unstable hashrate on the pool (mine on sparkpool now) with c39. How can i fix it?
Rig with 3x1080ti and 4x1070.
kbminer - last version (0.6.4)
non custum parameter
You can’t fix this. The same situation is at MWGrinPool.
The “Stats” table has:
Stats | Today-1. | Today-2 | Today-3
Error | 19 | 0 | 0
Reboot | 0 | 0 | 0
What do these values mean? What kind of 19 errors?
There is a pre-release Kbminer, v0.0.4, support NVIDIA GPU C31 only.
This version have a feature that could work without CPU computing.
Choose this version on the group config.
Enable the feature with custom parameter:
-params *:cpuload:0 -params *:nocpu:1
Hi .When the Rocm version?Because I can’t install it on current fs,-low disk space for that.
Thanks.
