definitely not all hash is received by the pool
after 24h with a hashrate of 5gps in minerbabe, in pool average hashrate is 3.35gps
i consider switching to grin-miner in SMOS
Use the pre release kbminer 0.0.5 for 2080ti , set it in group configure pannel.
What is the pool? Could you try some other pools.
Hello! overclocking params don’t work on my 2080ti? any suggestions to fix it?
I have 1080ti running on 0.0.4 as per your earlier instructions.
And I also have some RX 8GB, running at 2gps on minerbabe and on pool is 1.5gps
On the same pool (grinmint) I am running some RXs on grin-miner on c29 and the speed is almost the same, so no differences
Kbminer submits solutions without verifying the difficulty, this is harmless for most pools and may increase the GPS on a low performance rig.
If the GPS is lower than that reported by Minerbabe duing to this problem, we will add a optional feature to verify the difficulty before submitting.
Try to set the power to 80% of the max value.
so max pl is 300w - so I need it to change for 240?
I change pl to 240 - the temperature of the card is more low now! so pl params is work fine! But memory and core overclocking is still don’t change… I tried to add core clock +85 and memory clock +1000 looks like it can’t applied -(
what’s the GPS for 2080Ti for C31 card ?
thanks!
The difference between 2 and 1.5 is a little too large. Since we need to be neutral, I can’t recommend pool to you, but I suggest you try a few more pools.
I I am trying now another pool (sparkpool) to check but first data confirms that not all hash is reaching the pool… after 2h out of 9gps only 6.8gps are on pool
try to + or - by 100 once, and check current frequnce in the rig informatin page by clicking the rig name in the dashboard.
about 1.7 GPS for 2080ti
this is same with the official Linux miner i think…
Hallelujah, it works!.. I’m sure though that I was trying this version in the depth of night…
Your OS doesn’t work on z270 chipset. doesn’t boot and if it does it doesn’t find network connectivity. Fix this or release your miner with a high dev fee.
has anyone tried it on Z370 chipset?
p.s. I have successfully started Minerbabe on Z270-A PRO MB. First update your BOIS, then try different USB flash drives (USB 2.0 may be a solution too), different Minerbabe versions and different boot methods (UEFI and non-UEFI.
Please, add EVGA Nvidia cards fan control support to minerbabe. Now only one fan working.
https://forums.evga.com/How-To-Video-Card-Fan-Speed-Control-Under-Linux-m1128675.aspx
https://forums.linuxmint.com/viewtopic.php?t=245937
Another question - what is the sudo-password in this operating system?
I have Z370-A too. All working…
