My CPU is slow and grin-miner does not optimize for that yet so my graphrate is lower. Hopefully half of my fees to minerbabe go to implementing features like this into grin-miner. I’m guessing most of the benchmarks for GPUs currently are a single/few GPUs on a recent CPU and not 10+ GPUs on a traditional miner-grade CPU.
I had many pervert exercises with this MB just yesterday.
Finally, after BIOS update and after trying different USB sticks I found it working with KINGSTON DataTraveler DTSWIVL/16GB 16Gb (which I bought especially for this) and Minerbabe 4.11. It was booting with 4.12, but refused to mine, don’t know why, 'cause I was not able to see Minerbabe OS output for some reason (tried Ctrl+Alt+F1 with no result). There are 6x1070 on that rig.
Check latest available BIOS for this MB, they say that it improves USB compatibility. It can help…
Are you using over 10 gpu in one Motherboard ?, ah that’s why i’m still on 4 GPU on one MB.
Have you successfully run your setup with grin-miner on Ubuntu? I find if that works, minerbabe works.
Even with 6 on same motherboard with LGA1151 celeron there is slowdown.
It’s so fast and easy to buy a more powerful CPU for upgrade. In Russian, this is called “miser pays twice.”
I have no so many spare time to experiment with Ubuntu, sorry…
Hawaii, we need to find one
There is a pre-release Kbminer, v0.0.4, support NVIDIA GPU C31 only.
This version have a feature that could work without CPU computing.
Choose this version on the group config.
Enable the feature with custom parameter:
-params *:cpuload:0 -params *:nocpu:1
is it only for minerbabe os ?
I see now that my rigs and my fellow’s rigs are “Offline” in Minerbabe dashboard, but at sparkpool’ side everything is OK.
Thank you, my graphrate has increased by 10% with that adjustment
@Rabinovitch the dashboard is back up
Hi! Do you also see this hashrate in the pool?
Because I have roughly 2gps on minerbabe and only 1.4gps on grinmint.
Thx
Hello!
I did not use any password in Group config but when I request payout from grinmint it says “Payout failed. Error: Missing password error.”
Anybody had issues with payout requests without password?
Thx
Did you use password to mining at grinmint before? If so, use that password.
If not, try to use “x” as the password when payout.
Yes I used a password before but that did not work.
Strangely it worked with “password”.
I guess is grinmint’s issue with allocating passwords on different accounts with same email…
Anyway, thanks for this OS, you’re doing a great job!
Can Minerbabe work with RTX 2080Ti? In my case (single 2080Ti inserted in PCI-E x16 slot, 8 Gb DDR4, Core-i3 6100) I only see zero hashrate and a couple of warnings like these:
time=“2019-01-24T09:30:32+08:00” level=warning msg=“[Device: 0] Run error: Device 0 GPUassert: out of memory mean.cu 434”
time=“2019-01-24T09:38:51+08:00” level=warning msg=“[Device: 0] Run error: Device 0 GPUassert: out of memory mean.cu 434”
Minerbabe v4.12&v4.11
Hi.I got almost every share “rejected due to low difficulty” , on minerbabe , on grin-pool…,is it possible to fix that prob?
Same problem as Rabinovitch’s but with my 1080Ti on C31. The other 1080ti and 1070 work well. What can be a problem? 16GB, FX-8350.
All 3 GPUs work perfect when switching to C29 in Minerbabe.
