Hello,
i installed minerbabe on me rigs, but 2 of them not connecting and i get an error Errno-3
That its mean ?
thanks for help
Hi,
is there a way to mine with your miner on z270 A pro motherboard cause network driver is missing obviously as there is no network connectivity when start miner?
IP address is static and everything else was made as it needs to be by my side.
Also tried dynamic IP same problem exist
On win everything works with c29…so how to manage that???
Z270-A PRO (MS-7A71) MSI? ??? i cant mine too on this motherboard
second day cant start , another motherbords work ok
I am trying also on h81 and some libraries are missing but it can connect on network at least
i tray to change bios seatings but same problem
thanks on info…wanna try that…I am trying to put image on another USB and using 4.12 version…tried with 4.11. On h81 have network but there is some errors on dashboard.
4… version from where you download?
4…11 sorry can you give a link?
4.11 version not work on Z270-A
yeah 4.11 not working as 4.12 too…
it is on minerbabe.com 4.12 I would like to send you link but it is so slow I cannot turn on site.
hello NVIDIA P104
it cant work
Hi there!
This is the best/easiest to use OS available! Great work for the dev!
I have a few rigs connected but I am reluctant to connect more because it looks like reported hashrate it’s way higher than poolside hashrate…
Anybody can confirm/infirm?
Thx
I am running a 1080Ti,
When I want to run C29 it works flawless (way slower then windows)
But when I want to run C31 then it say out of memory…?
C31 works well On 1080ti,Please send your screenshot or log to minerbabe@mcarlo.com
how is the C31 performance?
Thank you for providing the service, I can tell this took a lot of talent and effort to complete. For anyone wondering I have been mining with this software with accurate hashrates for the hardware for a few days.
I only considered using your software because I noticed that you agreed to comply with @tromp developer license. You are doing the right thing and still hopefully providing a profitable service.
Please continue to follow through with your agreement so that I can continue to use your software.
Cheers @ ~7GPS c31
7gps c31 = may I know which (and how many) gpus ??
14 x gtx 1080 ti = ~7gps c31
have you try the grinminer from grin team ?, That should be roughly the same or better.
