When a GPU of the worker has no share for 5 minutes, the state of the worker will change to abnormal, which means the worker is not running at its best.
If you have applied the OC settings, we have no way to get it back to the default.
How do you upgrade versions of minerbabe? Do you have to download a new image?
Sure. Then flash this newly downloaded image to USB drive.
Too low for itās fast HBM2 memory at 2048bit-wide busā¦
only 4.15 version on the site. No new image. Ugh
When the next version is released, we will update all online machines. Until then, you can re-burn to update.
when lolminer 0.7.6?
lolminer latest version is 0.7 stable version, Minerbabe have supported.
https://bitcointalk.to/index.php?topic=4724735.0
Hey - I use Minerbabe to mine Ethereum.
If I want to mine XMR - considering that the mining software recently changed due to the Cryptonight forks on most coins, do I need to wait for a new version of Minerbabe that contains the new mining software of is there a workaround this ?
Thank you
We have updated to the latest miner for XMR already.
Yup - I saw that so the software is updated automatically regardless of the minerbabe edition I am using. I thought I need to re-flash another usb drive each time a new one comes out.
Iāve been rocking the XMRig for the past hours⦠is there a possibility to edit the config file of the XMrig miner ? Seems that the autoconfig settings for my RX580 cards are less than ideal and it would be helpful if I could edit the file like I usually do with my windows rigs. Usually with Cryptonight - you need to play around with the intensity/worksize settings until hitting the sweetspot for each different rig.
Thanks
Yes, the software is automatically updated.
Editing files is not feasible in MInerbabe, the machine gets configuration info from the server every time it restarts. You edit the file and it will disappears after rebooting. I suggest that you do this by grouping-custom parameters, just add the parameters for the intensity/worksize in the Custom Parameters column.
Does this support Radeon Vii and tuning functions?
Last I tried, it didnāt support it yetā¦
