I’m sorry to reply so late.
This may be caused by server load fluctuations. During that time we were on holiday. Is it stable now?
Yes, and we released KBminer 1.0.1, c29, vega 8G, 4.06gps, you can try.
It seems that the U disk is broken.
I am sorry to reply so late.
That may be that some configures are incorrect. Is the problem solved now?
You won’t support Vega Vii with 16gb hbm2 on C31…
Back to windows I go
Does this problem still exist? This may be a problem with f2pool.
I am sorry to reply so long.
There are some problems with our system running on the Z270 motherboard. This issue has yet to be resolved.
If you have a lot of machines, please let us know your email, we will update them remotely, we have a remote update mechanism.
I’m sorry for reply so long.
With a lot of feedback, the z270 motherboard doesn’t work on Minerbabe.
We do not recommend that you use the old version of img.
This issue has not been resolved. We will solve this problem in the follow-up work.
Has this problem been solved? I remember seeing this picture in the telegram group.
This is a good suggestion and we may support this feature in the future.
You can set the core state in OC operation.
Does OC not work? let me know more info about your cards.
Yes, you can ignore it.
Vega‘s OC setting have some issues, it has fixed now.
Is this problem still there?
This problem did exist in the early stage, and we have optimized it. This problem has been greatly improved.
Check the router settings, we supported this motherboard.
