I have seen that you edit c31 and 2080ti for it. But it still say insufficient memory 9029.27 MB available on device
seems for 2080Ti, the miner is not very Stable and sometimes died!
and still a lot of rejected shares too.
We’re pleased to release Bminer 14.3.0.
Improve the performance for Cuckatoo31.
Support 2080Ti for Cuckatoo31.
Reduce the CPU usages for Grin / Aeternity by default.
Reduce the likelihood of rejected shares for Cuckatoo31.
Please see https://www.bminer.me for more details.
Please see https://www.bminer.me/performances/ for performances of Bminer on mining different coins.
Happy mining!
Failure to run prompt memory under WIN 10
Same, lots of rejected shares with 14.3.0 running cuckatoo31.
14.3 on cuk31 with 2080ti : it seems fidelity is extremly bad, yes it perfoms 2,1 to 2,2 GPS per card but real GPS seems to be 1,1 per card (also reported as 1 to 1,1 by bminer)
I confirm rejected shares is high (around 5%)
Yes. I have too many rejectes…
Under windows. It say I do not have anough memory. When I run another windows miner I do not have this problem
Getting this error whenever I use more than 5 GPUs.
It was handling 6 GPUS with all 1070 tis, i swapped one of them for a 1080 TI and now it does this at 5 GPUS.
I found BMiner hung on 2 PCs with 1 and 3 2080Ti, Ubuntu 18.10.
LInux, 410 Driver, GrinMint Pool, 14.3.0
Rejected due to low difficulty
What does that mean ?
I achieve 2.12 GPS locally with 2080ti but grinmint report 0.28. Normal?
Ovserve it for several hours. You will probably find it hanged after several hours.
Hi, please give me for information about your card model, operation system and the driver version, pool, thanks!
Hi, doge, please give me for information about your card model, operation system and the driver version, pool, thanks!
@realbminer just tested 14.3.1 and was not getting any shares.
We’re pleased to release Bminer 14.3.1.
The release provides:
Improve the performance of Cuckaroo29.
Reduce the likelihood of rejected shares of Cuckatoo31.
Support Nicehash for both Cuckaroo29 / Cuckatoo31.
Please see https://www.bminer.me/releases/ for more details.
Sample usage of mining grin over Nicehash:
bminer -uri cuckaroo29://1DQ4bZpFTDiSNk2CWLEFWK9K96rBFP2Hv@grincuckaroo29.usa.nicehash.com:3371
bminer -uri cuckatoo31://1DQ4bZpFTDiSNk2CWLEFWK9K96rBFP2Hv@grincuckatoo31.usa.nicehash.com:3372
Happy Mining!
i dont see any hashrate speed only received new job is that ok ?
i just restart again and now work
