Hi,Will a GTX 970 4gb work with this miner on linux?
We have just published a step by step guide to mine Grin with Bminer on Windows
Let us know what you think!
Hi everyone!
We are glad to announce that we just donated half of the collected Grin devfee so far to Grin general fund. And we’ll keep doing donations to Grin general fund.
We are proud to support the Grin developer team and the future of Grin.
that’s so great… will try to use bminer when you have C31 Version.
Currently bminer only supports the Cuckaroo29 algorithm.
May I ask if you run it on stock settings or not?
any plan for C31 algorithm support? i think in few months, the C31 algorithm will take more and more weight… thanks!
When I attempt to run bminer I get the following error:
Failed to initialize the CUDA platform: CudaError: Could not initialize the NVML library
Running Cuda 10, working fine with regular grin-miner software… Any ideas?
We’re pleased to release Bminer 14.1.0.
Improve performance of AE / Grin on Turing cards.
Improve performance of AE / Grin on lower-end CPUs and Windows platforms.
Support mining beam on leafpool and nicehash.
Fix the regression where /api/v1/devices is occasionally unresponsive.
AE mining on stock settings:
- 11.00 Sol/s on RTX 2080ti
- 8.3 Sol/s on RTX 2080
Grin mining on stock settings:
- 10.8 G/s on GTX 2080Ti
- 7.90 G/s on GTX 2080
Please see https://www.bminer.me for more details.
Happy mining!
Absolutely no difference on 1070.
Heard about the issue of same type of cards and/or rigs getting different speed? I got 2 almost identical rigs, with some of the cards giving me 4 gps while the others are stable at 6 gps.
8x1080ti same brand
G4400
Different mobo
how to use Bminer to mine Grin 31/29 on windows with AMD cards?
nvidia only. use gringoldminer for amd
Hey guys i have 1080tis and 1070tis bon same rig and keep getting failed to fetch device status for a number of my cards … what am i doing wrong… Using the latest bminer… Should I switch back to old one?
how about C31 miners? waiting for this
Yep - my 1070 no change - but on the RTX 2070 there is some improvement
Does anyone else here get a virus alert in Windows 10 when they download the latest bminer zip? Windows built in virus detector says the download is infected with Adware:Win32/Unwaders.C!ml
https://www.bminer.me/releases/
14.2.0 (Current)¶
- Experimental support for Cuckatoo31 on 1080Ti.
- Fix the regression where ETH dual mine fails to start on Windows.
- Improve performance on mining Aeternity.
- Support tweaking the CPU usage for mining AE / Grin with the
-intensityflag.
Can’t get it (cuckatoo31) working on my 1080ti.
[FATA] [2019-02-07T06:43:46-06:00] Insufficient memory 9171.7 MB available on device (#0). Unable to run the solver
[WARN] [2019-02-07T06:43:47-06:00] Miner died! It will be restarted soon...
It just doesn’t work (at least for me with 1070s).
