Bminer 15.7.6 Fix Cuckaroo29d on RTX-series cards
When will be the performance regression removed for RTX20XXs?
13.2.0 - released earlier today.
you don’t have enough memory
is it support C31 algorithm?
No. If bminer has plans to add c31 support I am sure they will announce them or just tell us when they release a version that does.
bminer thread on bitcointalk
To Mine Grin
Currently bminer only supports the Cuckaroo29 algorithm. There are a few things that need to be customized for your own usages:
  • Substitute bminergrin with your own GRIN address.
  • Substitute worker to your worker name.
  • Substitute foo to your password.
  • Currently bminer only supports the Cuckaroo29 algorithm. For example:
    bminer -uri cuckaroo29://bminergrin.worker:foo@grin.f2pool.com:8898
ok good to know…thanks!
Please see Bminer 13.2.0
Improve the performance of Turing GPUs when mining Grin.
Bminer 13.20 Grin mining on stock settings:
  • 10.00 Sol/s on RTX 2080ti
  • 7.60 Sol/s on RTX 2080
  • 7.00 Sol/s on GTX 1080Ti
  • 4.50 Sol/s on GTX 1070
  • 3.10 Sol/s on GTX 1060 6G
  • 6.66 Sol/s on P102
  • 3.90 Sol/s on P104
will you guys release a C31 Version? right now, seems we can only use it to mine C29… thanks!
Why im getting 5.65 sol/s on gtx 1080ti it’s not the same as your list of hashrate above let me know what should I do to reach the hashrate above?
1080Ti definitely boasts up to 7G/s stock, and 7.8G/s @ +150 core / +800 mem / PL- 200W
https://www.bminer.me/releases/
seems bminer have a new Version?
still no C31 algorithm?
thanks!
What driver version of your GPU? my rig still on 399version cuda 9.2.
hey, developers of Bminer WHEN and HOW we will use AMD cards to mine Grin31 or 29 ???
Last driver for Linux : 410.93
i mean for windows .
No idea… :slight_smile: I’m runing it on Linux Mint
I’m running bminer on windows but worst result im getting 3.53 fixed after few hours getting this. GTx1080ti is in GPU 0
Bminer version 14 and still has no support for grin31 ?
same question, hopefully they can support it in next Version.
