Bminer 15.3.1 has fixed the CUDA error 700 on P106 and the error 0 GPS hashrate on 2070/2080.
I have the same problem. I’m stuck on 15.0.0 on Win7. Hopefully it can get fixed.
Is it working fine in ubuntu?
Buddy, I don’t know what are you doing, but after bminer 15.0.0 all newer versions (including 15.3.1) produce good rates only on the first GPU on the rig.
OS: Linux
Everything is OK with my 4x2080Ti rig. Ubuntu 18.10. BMiner 15.3.1.
Here is a fresh screenshot:
First of all, remove that terrible Win 7 !
We are in 2019, I can´t really understand why people still use that crap.
Win7 is the best OS by Micro$oft ever.
The only really reason why I use Win7 is that in the first few days of Grin Mining the 8GB RTX cards were working only on Win7. That’s because of some weird way of how Win10 allocates memory …it was not allowing the miner to work properly. Not sure if that was fixed now… but people in the first few weeks were using Win7 and I was under the impression that Bminer still supports that.
I’m not from the past
Ok, no problem.
Cannot get bminer to work with my 6x RX580 rig. Itś running Ubuntu 16.04 with AMDGPU-PRO drivers 17.40.
Getting the following errors:
How to fix?
Edit:
I also tried the latest version (15.3.1), gives a slightly different error:
Ok, these are mine 5 x 1070 Ti:
v15.0.0
v15.3.1
As you can see for v15.3.1 only first GPU shows good rates
Does reboot help? 20 characters…
We’re pleased to release Bminer 15.4.0.
The release provides:
- Improve performance of Cuckaroo29 / Aeternity.
- Improve compatibility on Windows.
- Add an experimental flag --fast to improve the performance for Cuckaroo29 / Aeternity, but it might lead to unstability on some systems.
Please see https://www.bminer.me/releases/ for more details.
Happy mining.
finally! thanks. Hope it will fix my issues.
Hi. How to fix this trouble? Win7-64 Nvidia 419.67
Bminer 15.4.0 got this error, 15.3.1 is OK.
Bminer: When Crypto-mining Made Fast (v15.4.0-9e272fc)
Detecting platform
CudaError: Unknown error: c:\windows\system32\dxgi.dll
Miner died! It will be restarted soon…
Are u going to fix bug after 15.0.0 when only FIRST GPU works properly ?
It would be helpful if you can give me information about the OS and driver version. Thanks!
I also have this bug!
OS - HiveOS
driver Nvidia 396.54
BMiner 15.4.0 can’t start at single 1070 under Win7 with 398.11 driver.
any error on the screen?
We will working on fix it.
