The reason was just an old version of the driver…
But now I see this error from time to time after many hours of normal mining:
But I have upgraded it to 419.67! So only reboot can help to fix this error and start mining again.
It´s the same issue that occurs to me.
I´ve the latest driver but after few hours or days the miner just dies and restart is necessary to work properly again.
Interesting that this issue occurs only on PC with single 1070 card, on my rigs with 5-6 GPUs everything is well.
Isn´t it just problem with 1070 - 1080 gpus?
I am mining with one 1080 ti & one 2080 ti and I think these cards together make it not comfortable for miner. Are your stable rigs composed of pure 2080 Ti or also 1080 Ti?
may I ask what’s the OS?
may I ask what’s your OS please? thanks! we will fix it ASAP.
Win 10 Pro 64bit.
Thanks for your support! ![]()
Btw, I think it´s the same issue on both Linux & Win OS.
I made the whole topic about this issue, if you want to go through it, check this link please :
Win7 x64 Maximum, 20 characters. )
Are u laughing ?
Linux aw1 4.13.16-hiveos #1 SMP Tue Apr 17 18:30:28 EEST 2018 x86_64 x86_64 x86_64 GNU/Linux
Mining C31 with my 2080 RTX TI on Linux with Bminer used the 11GB algorithm, but on Windows 10 x64 Bminer sees only 9GB free and falls back the 8GB algorithm.
I checked using nvidia-smi that there’s no process running on the GPU and it reports almost full 11GB free. My display is connected to the integrated VGA so the GPU should be totally available for mining.
Is it a known issue? Are there any workarounds? I use Bminer 15.4 and the newest nvidia drivers.
I can´t even run C31 on Win10 with my RTX2080 Ti.
It runs only solo, but when it´s together with GTX1080Ti, it is forced to work lower on C29 8GB algo.
On Ubuntu, it can´t run too on C31. Only when solo.
We’re pleased to release Bminer 15.5.0.
The release provides:
- Improve the performance of the Cuckatoo algorithm.
- Support dual-mining ETH and VBK.
- Add the parameter
-versionto output the version and exit.
Sample Usage of dual mining ETH/ VBK
bminer -uri ethash://0xb76d43eAaB2e905028a7f0F3aF13C7A84c477B9f.worker@eth-us-west1.nanopool.org:9999 -uri2 vbk://VAR5uzCpFNfmTDZQQmfHUgbpY7NS93.worker:pwd@vbk.f2pool.com:3500 -dual-intensity 10
-dual-intensity is for adjust the performance manually, so you can adjust the intensity by adding it at the end.
-dual-intensity 0 means mining eth only.
-dual-intensity 3~10 is recommended.
Please see https://www.bminer.me/releases/ for more details.
Happy mining.
Thanks for the update, however, the unknown error still lasts …
CUDA error DRIVER: ‘1’ in func ‘bminer::cuckoo::Cuckoo29SolverCudaBase::InitializeCudaEnvironment’ line 212
[FATA] [2019-04-15T11:19:18-07:00] Fatal cuda error in GPU 0. Terminate soon…
Pretty high temps, aren´t they?
I am not crossing 60°C. Why don´t you run fans 100%?
I don’t know how to set it to 100% speed under Linux.
So it seems that the driver is setting the speed, so I think nVidia engineers know their work well and te GPU is OK in this mode.
I will try Win10 on this rig when I’ll have some free time… just for this purpose.
Now I understand. I was thinking exactly about this thing when I was testing mining on Ubuntu (how to control speed of fans), but never come to that point and switched to Win.
To achieve less than 60°C on my RTX it has to run 100% speed, but the GTX is running just on 65%. But it´s probably about the build of the card and the brand. Anyway, I also added some extra F8 Arctic fans under the cards, so it´s pretty well cooled with these external fans.
I’m getting an 8% improvement on Grin 31 over the 15.4! And the power usage and temps are a little better. NVIDIA Grin 31 : Thanks!
EDIT: 3% at the pool side, but still, very good!
Bminer 15.5.1
Fix the regression that Cuckaroo29 fails to work on Turing cards
Significantly improve the performance of ETH / VBK dual mine.
Known issue: There might be performance regression for Cuckaroo29 on NVIDIA driver 410.66. Please use 410.79 or 396.37 instead.
Happy mining.
TCP 50% Dual mining performance
2080TI
Ethereum(MH/s ) 50.194
VBK (MH/s ) 501.928
2070
Ethereum(MH/s ) 35.39
VBK (MH/s ) 354.02
1080TI
Ethereum(MH/s ) 43
VBK (MH/s ) 430
1070
Ethereum(MH/s ) 25.5
VBK (MH/s ) 255.43
P106
Ethereum(MH/s ) 17.4
VBK (MH/s ) 171.4
