sound like scam when you can only deposit
it only took 2 years for Grin to come up with one functional exchange
You can now deposit and withdraw GRIN on Bittrex again, I think…
all exchange start support old wallet bittrex use file slate
Supporting old deprecated methods is worse than delisting. We should encourage them to either switch or delist. If they can’t implement a switch to slatepacks, then you wouldn’t want to trust them with your money anyway.
I realllly want to buy some GRIN
edit: really good experience with tradeogre!
Gate.io active again:
Also Bitforex. They still use HTTP but it’s active.
Can @bluimes update the topic?
- Gate, Tradeogre, Bittrex supports Grin’s slatepack and they work.
- Bitforex and Hotbit supports and works for http. Not slatepack yet.
- Kucoin has been closed to Grin transfers for a very long time.
Bittrex closed again. They worked for two days and closed it again.
I have tested by withdrawing 1Grin using Slatepack Adress (i.e. address begining with grin) from Gate.io and it is successful. It is fast (less than a minute for appearing in Grin++ and few more minutes to wait complete confirmation). Great!
For deposit, I found it has an serious issue. It requires a Memo code which should be appended to the deposit number. Say Memo code is 123456, then your deposit number can only be #.123456, where # is an integer. It renders this deposit method unuseful for automatic transactions, such as from POOL to Gate.io.
Gate.io has completed the GRIN wallet upgrading and added support for Slatepack addresses. The obsoleted URL addresses will not be supported any longer. This upgrading brings some major changes:
- Slatepack address will be used for depositing GRIN. The Memo displaying on your deposit page is exactly the decimal part of the amount you should deposit. For any amount you want to deposit, the decimal part must match the memo exactly, while the whole number part can be of any number. For example, if the Memo for your GRIN deposit page is 722413, then you can deposit 1.722413, 2.722413, 10.722413 , 100.722413, etc.
- Slatepack address will be used for withdrawing GRIN. The URL address is not supported any longer.
nice so we dont need spend money to testnet exchange
I think the little bump of Grin price today has something to do with this support by Gate.io. lol
How to solve this problem if we are using Ironbelly?
I sent 0.6457xxxx (Memo 6457xxxx), Ironbelly read after sent 0.646
Was the deposit successful after all? Ironbelly rounds Grin amounts to 3 decimal places, but only when it’s showing amounts.
That seems like a questionable feature.
Most users, when sending amounts with more than 3 decimal places, would want to see them all.
Just to reiterate: it should not round when sending, only when showing amounts (so you can send 0.123456, but later in the transactions list it will show 0.123). Although, I agree, that this is rather unnecessary and I will remove this in the next release.
So far the deposit has not been credited to the gate.io account. This exchange requires 100 confirmations to deposit, but there is no sign the coins have been credited or pending or processing. In ironbelly wallet, the deposit was successfully sent.
