You can press on View kernel in the transaction overview to check was it mined or not and how many confirmations it has. Also in case gate.io would not see your transaction automatically - you can send them the link to the kernel as well.
This, and you should also be able to confirm that the amount was correct to all decimal places by looking at the kernel.
Another mention to KuCoin to update system
Gate.io active. Now you can trade, make deposit and withdrawal again.
when you last deposit or withdrawe from bittrex and hotbit?
Bittrex still using old method, not support slatepack. Hotbit is the same, not support slatepack.
Bittrex supports withdrawing with slatepack works now.
