I have Grin plus plus V0.7.5 wallet. The problem is under Status 2/4 Downloading State. It keeps downloading at 2/4, it hasn’t moved to 3. It just keeps downloading 2. Does anyone know how to fix this? Please.
Thank you
Thank you
message with a possible solution to problem is fixed on channel
or you can ask developer a question
?? I don’t and won’t use telegram. Just like I don’t and won’t ever use facebook.
Telegram not equal facebook
I believe @david may be able to help you right on this forum.
Thanks for tagging me. Here’s the fix:
* Delete %userprofile%/.GrinPP/MAINNET/NODE/TXHASHSET and %userprofile%/.GrinPP/MAINNET/NODE/DB/PEERS (%userprofile% just means C:\users\<your_username>)
What will happen to the coin I have in the wallet?
They’ll still be there. They’re encrypted and stored in %userprofile%/.GrinPP/MAINNET/WALLET, which you won’t be touching. You can also always restore them using your seed words
Thank you David. All fixed.
