Grin++ v1.2.6 is now available, thanks to the users that help us testing before releasing.
This version specially improves the sync mechanism, it should not fall into an eternal “Waiting for peers” state. Also, the resync action was fixed and a button to export your transactions into a .json file.
Known issue: some desktop users reported some rare crashes of the node, please if you’re facing this let us know Telegram: Contact @GrinPP.
The upgrade plugin is a bit buggy. Probably we should replace it. I recommend to close Grin++, make sure the node is stopped, download the installer from there website or GitHub.
I do believe @davidtavarez is working on the known issue. You can restart the node, but if it becomes too problematic, you can downgrade to 1.2.5 for now
