Today I went into settings and clicked “Resync Blockchain” since it seemed like I was stuck.
Since then, it has got to “Status 2/4 Downloading State” gone all the way to 100% then resets to 0% and starts again up to 100% and keeps looping. It never gets past this step and has been doing this for the past 9 hours.
Looks like I broke it. Is there a simple fix for this?
Probably just deleting %userprofile%/.GrinPP/MAINNET/NODE/TXHASHSET and %userprofile%/.GrinPP/MAINNET/NODE/DB/PEERS would’ve been enough, and would avoid resyncing headers. But Neo’s solution should hopefully work.
There is an underlying issue though that was introduced in a recent release. I’m yet to track down the exact cause, but it appears if you start syncing from a peer and they disconnect, your txhashset (the ‘state’ referred to in step 2) gets locked, causing later attempts to fail as well. I’m investigating the issue and will create a new release once I find the cause.
