after getting CPU mining working, i felt confident enough to purchase a RTX 2080, in anticipation of the main-net going live.
I am having a devil of a time trying to get drivers installed for this card. I have tried multiple flavours and versions of Ubuntu , server and desktop.
If anyone has successfully got this card working could they please post a rough outline of what they are using. I don’t need a guide, but a few details would really help.
Things I would like to know:
what distro
version
desktop or server
version of drivers used? (from the os repository or from Nvidia web site)
version of Cuda toolkit used? (from the os repository or from Nvidia web site)?
any tips or tricks that were needed to get it working
these RTX cards appear to require a computer with 8 GB minimum system ram
i only had 4gb and the rest of the system was old as dust, pentium dual core 1.8ghz
solution new i7 and new motherboard with integrated intel video for the system video and 16 gb of system ram, this should give me some room to add cards
Have you successfully start more than one 2080Ti under Ubuntu?
I tried to start three 2080Tis under Ubuntu Server 18.04 (MB: Gigabyte Z370P D3, 8 Gb RAM, CPU: Pentium Gold G5400). After system updating and installing the driver (nvidia-driver-410, tried 415 either) nvidia-smi shows only one GPU which can mine Grin without any issues), other 2 GPUs are displayed only with ‘lspci’ command.
