Mining collapses on C31 RTX 2080 TI - PLEASE HELP
hey there,
i installed ubuntu on my computer and installed all new nvidia drivers as well as new CUDA drivers
i rebooted my computer without GUI and startet the miner
it connected to the server and mined for 2 days before it suddenly crashed out of nowhere
now when i reboot and restart the miner i get a screen like this and the mining stops
has anyone had similar issues? please advice!
thanks
What is your Ubuntu version? Try to re-install in (18.04), and install only nVidia driver, without any additional CUDA downloads.
Update your motherboard’s BIOS to latest version if you haven’t updated yet. What is your PSU?
i did reinstall everything and i am using the latest 18.04 ubuntu version
i think the card is just not working properly
i tried mining c29 again and even on windows it crashed
screen with a million artifacts when it hit 63 degrees or so
Did you tried other torture tests on your graphic cards?
Seems you will need to take a look at the upgrades: https://github.com/mimblewimble/grin/releases/tag/v1.0.1
There are no upgrades yet for grin-miner: https://github.com/mimblewimble/grin-miner/releases
So may be it’s time to replace a motherboard? What is your current model?
I understand that the miners still have to reference the nodes so the latest version v1.0.1 might change your set up.
Hi Silver, follow exactly this commands:
cd ~
mkdir grin
cd grin
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-repo-ubuntu1804_10.0.130-1_amd64.deb
sudo apt-get install build-essential dkms
sudo dpkg -i cuda-repo-ubuntu1804_10.0.130-1_amd64.deb
sudo apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pub
sudo apt-get update
sudo apt-get install cuda-libraries-10-0
sudo reboot
cd grin
sudo apt-get install cuda-toolkit-10-0
export PATH=/usr/local/cuda-10.0/bin${PATH:+:${PATH}}
nvidia-smi
nvcc -V
wget https://github.com/mimblewimble/grin-miner/releases/download/v1.0.2/grin-miner-v1.0.2-480780314-linux-amd64.tgz
tar -vxzf grin-miner-v1.0.2-480780314-linux-amd64.tgz
cd grin-miner-v1.0.2
nano grin-miner.toml
(EDIT YOUR CONFIG! with nano or use something better)
./grin-miner
tell us if it works now…
