hi i have a brand new rtx 2080 ti running on linux mint x64 with cuda instaled corectly then i boot up using the intel 915 gpu for display with the rtx disconeted all runs ok mining on 29 but when i go 31 i get this error
Jan 20 16:11:15.064 DEBG Mining: Plugin 0 - Device 0 (GeForce RTX 2080 Ti) Has ERRORED! Reason: Device 0 GPUassert: out of memory /home/chris/grin-miner/cuckoo-miner/src/cuckoo_sys/plugins/cuckoo/src/cuckatoo/mean.cu 429
I was getting that error on windows, I was running grin gold miner ver 2.5 and then 2.6, it wasn’t until I installed ver 2.8 that the issue was resolved
single card also tried booting to terminal no gui on boot using ssh to run and same error it runs fine on cuckatoo_lean_rtx_cuda_31 but out on memory with cuckatoo_mean_rtx_cuda_31
fixed it by forcing linux mint to boot to console with sudo systemctl disable lightdm and added text and nomodeset to grub config and using console to run miner and openssh server for wallet
