Your Niffler wallet is a great piece of software, but I have some issues with it. I think it’s great that it can use the official blockchain data and daemon as a local node, however, it should not modify the main installation config files. It doesn’t even ask.
It’s maybe also questionable, if it’s a good idea to launch the grin daemon in the background and not exit it after quitting the wallet - as default behaviour.
Niffler does a lot of things in the background without the user knowing it. That’s not the best practice. Also, when I shut down the grin daemon via task manager, it crashed really bad (some error like: some output set was already spent, rejecting block), and I had to sync the chain from 0.
Howerver, Niffler want to be the first grin wallet for general user who has not installed the grin cli wallet or has no experience with command line tools.
The default Niffler options (which may be a little different from the default option of grin cli wallet) is what we think best for normal people.
And there is an option to close grin daemon when quit Niffler.
Can confirm that I seem to have a 5% chance that Niffler doesn’t accept my pwd, although it’s correct. Not a big deal for me, but curious what’s the problem. (also win10x64)
Another thing about Hedwig: It would be great if I could have a somewhat static address. Maybe if I could say, “please give me https://5558092394189555.v1.hedwig.im , if its currently free”. That would be great.
OK…I FOUND
I had grin** 0.6.4 running, that caused my issues. Even if I turned it off… Needed to reboot and ONLY run nifter, now works great.
My next question is, how stable is this to run? I have grin being deposited almost every 2 days as I am mining. Is this going to be supported as we go further? I will run a full node all the time??
Plus my 2 cents, in order to keep a static IP I use Pure VPN and I get a static IP from them… seems to work well with my wallets!!!
@ghatazu A static address may be against your privacy.
@njako you mean you deleted your wallet and restore it use seed with your old password, then failed with “Invalid Arguments: Error decrypting wallet seed (check provided password)” ?
