Im looking for replacement fans for the full sized iPollo G1.
I am not able to get any response from iPollo.
grin price up,welcome back for 2 years
.what is the meaning of replacement fans?
I got the word fans,I think what you mean.you could buy the fans in taobao.
Ive been mining GRIN with a G1 Mini for 2 years and just got a full-sized G1, but the fans really making noise, think they need replacing.
It uses industry standard. Just measure a fan in mm diagonally (including housing), and look for ASIC fan with same pin layout. That’s how I found G1 fan replacements some years ago. You want ASIC fan with high RPMs (6k+ range), that’s how you’d search.
They’re 120mm fans, right? Could you please provide a pic of them? I may know a good quieter replacement fan, just wanna make sure the CFM airflow is high enough.
I found regulad 120mm fans work fine. Thanks
