How do i mine to my wallet?
Hello,
i just finished to
  • install grin node
  • init wallet
  • set up grin-miner
However, i am not sure if i´ve setup grin-miner correctly to mine to my wallet. How do i do that? Do i have to specify 127.0.0.1:13416 as stratum server adress in grin-miner.toml ? Can i comment the login and password lines out in grin-miner.toml ?
The tutorial i read doesn´t state this….
Hope you can help.
Regards, impact79
Ok, it seems that grin-miner comes with a config to mine to the local wallet / node automatically. Please note that the default port seems to be 3416 rather than 13416.
You also have to enable the stratum server in grin-server.toml by setting “enable_stratum_server = true”.
