I am new to mining and just bought the G1 mini miner to mine Grin, but i am not receiving any rewards in my wallet. Tried below and also suggested by 2miner support
to keep the wallet running
open port forwarding for ports 3415 and 13415
drop any firewall on the machine
I have done all those still no transactions in the wallet. On the 2miner shows 15+ Grin unpaid balance since last night. Interesting every blog i saw it mentioned about the above ports but on my machine running the Grin++ wallet is listening on 3414 and no others . The wallet address shows in green and is running condition in the bottom. Please suggest
You don’t need to do any port forwarding, just to make sure your address is green. Also, you can join the Telegram group for more support https://t.me/GrinPP
Unpaid balance means that is not paid yet. If your unpaid balance is not 100% completed you will not receive. Check the total paid section not unpaid balance. You do not need to open ports except if you run grinnode. I also recommend grinmint pool as @satoshocrat mentioned. Here is the tutorial on how to setup your miner. grinnode.live/Grinmint_Instructions.pdf at master · Grinnode-live/grinnode.live · GitHub
