Grin++ Receiving Address Query
I had done it but did it again and it failed
I used to have " https://0304494e.ngrok.io" two there weeks ago and now shows " Failed to retrive address" on "receive " tab of the wallet
Just tried sending a small amount. It connects to your wallet, but immediately fails. Any chance you would be willing to leave that running for a few hours so I could investigate?
Yes, I will leave it on and thank you for looking into it
Some other thoughts:
Are you running Windows as an OS?
Is your software firewall blocking network access to the Grin++ application perhaps? Can you check to see if the application is allowed?
Yes , Windows 10.
I have checked the firewall and it is allowed .
Figured it out. Some clients fail to verify the ssl certificate with error “UNABLE_TO_VERIFY_LEAF_SIGNATURE” (no idea what that means)
Use http://je5x247fsixuabu3f56cb5poydaybbzn2dxnof2eqdwoyayczjqtwqyd.grinplusplus.com instead of https
I had tried "http: but trying it again now. BTW I received a small amount from you.
It worked , thank you very much for your help
Give me your address so I can send you back something
3ngg5chiucyvjxaymy46fypqbr3nfskj2lluygnz6hqys5lwxrcpqzad
Received. Thank you!
Thank you for your help. The exchange shows completed status on sneding the funds, I see it on the wallet in “Receiving (unconfirmd)” status for 25 minutes now !
Sorry for bugging you again, the transaction (transfer from exchange) shows unconfirmed for more than a hour and half
Is it Normal?
Is your Grin++ application frozen perhaps?
What is the highest block number shown at the bottom?
Its not Frozen , I sent another small amount to Dave after that unconfirmed transaction and went through
Current block number I see is 535307. Is yours similar?
Yes it is and it’s running
I would say it is not normal to be unconfirmed for that long. Transactions are usually completed within 15 minutes in my experience.
Have you clicked Refresh? Perhaps it just needs a jolt.
I Did
Sad part is that, Poloniex showing transaction is complete
You should check with @David again, as the grinplusplus.com server is in the middle of the process. Perhaps he can see if anything is delaying the transaction?
