Release: Android 0.0.1
This release is the first release of Grin++ for Android. Grin++ is an easy to use Grin Wallet, which does not store any personal identifiable information, there is no analytics; the little information that is stored like the session token is stored encrypted. Also, the node information like the wallets cannot be copied.
Features
- Create multiple grin wallets.
- Backup/Restore wallets via seed phrase.
- Send and Receive $grin via Tor and Slatepack Messages.
- Address availability checker.
- Transactions history.
- See the details of each transaction.
- Control Grin node using notification bar.
- Share the grin wallet address.
Minimum Requirements
- Minimum Android version required: Android 9.0 (API Level 28) .
- Architecture supported: 64bit .
- ARM: AArch64 or ARM64 .
- Minimum RAM: 4GB .
- Minimum Disk Space: 2GB.
Direct Link: https://keybase.pub/dtavarez/grin%2B%2B/apk/0.0.1/com.grinplusplus.mobile.apk
Google Play: https://play.google.com/store/apps/details?id=com.grinplusplus.mobile
Please, make sure that your device meets the minimum requirements.
Support
Since neither analytics or crash reports were added, the best way to ask for support is using the Grin++ Support Channel: https://t.me/GrinPP
Translations
If you want to see Grin++ translated into another language, please, feel free to contribute.
