Is this mobile wallet grin++ ready fo Fork Grin v.5 and funds are safu? Ore it wllbe need to upgrade???
not a 100% ready yet; this is v0.0.1, currently beta; a new version will be released for the next HF. As long as you keep your wallet seed save, it won’t be a problem.
When it will be? After HF?
Report:
Testing Withdraw with new slatepack method at TradeOgre, grin++ android wallet can’t generate a response from the slatepack message, it looks like there is a bug with the receive button after copying and pasting the slatepack message into the box.
Then I tried to receive grin with ironbelly android and the result was ok. So Slatepack message from Tradeogre was not in error state. I have also tried restarting and re-syncing grin ++ android wallet, and the receive button still doesn’t work.
After the coins are received, grin ++ android wallet can show the spendable amount of the coins, and the send button appear. The grin slatepack address is also green. The number of nodes is also now higher than before.
Note: Withdrawal only takes two steps (assuming asynchronous method only), then the coins arrive in the wallet, 10 confirmations until spendable (about 3-5 minutes).
Is there an updated APK link somewhere? This one seems outdated and is also dead. I am trying to install it on a de-googled device.
The current code has 2 annoying bugs. I was not available for weeks to work on them due to personal stuff.
@davidtavarez, you’ve done an excellent job!! Congratulations! It’s incredible to have a full node running on a mobile android device.
