Working! finally! didn’t work with me before cause i was using port 4416 as in grin gold miner , but that encrypted port dosn’t work with bminer
the only problem is there is too many rejected shares when using grinmint compared to f2pool
The encrypted port works with bminer if you have cuckaroo29+ssl instead of cuckaroo29
New version looks good. Thanks for that.
Another issue that cames up from time to time.
Get error: End of file
But i think its more pool related ?
thank you! merci! gracias! <3
After 12.2.0 update on Linux:
Get error: End of file, resetting in 5 seconds
Failed to fetch device status for device id: [number], Error code: 3
I have updated the tutorial, you can follow it and try again since the rejected share issue should be fixed already.
Would you mind share your bat file config here? thx
Failed to fetch device status for device id: [number], Error code: 3, The error indicates that the miner cannot get the statistics of the cards to monitor it.
About the error that end of file I may need to see your bat file, would you mind DM me it? thanks.
Hi there @bminer Is the bminer 12.2.0 also for c31?
Thank you
Currently bminer only supports the Cuckaroo29 algorithm.
Thanks, any timeframe maybe? Preciated
Still there’s too many rejected shares , please investigate this issue
Do you have in plans support AMD cards? When?
May I ask what pool is it?
After update to v13, the hash rate for 2080Tis dropped significantly (see GPUs 0-3)
Will there be any support for AMD cards to mine GRIN in upcoming releases? Thanks!
Hi @bminer Is this the new version also voor c31 algo?
Thank you for the help
Can confirm about 4.9% invalid shares
