Hello, this looks pretty neat. I’m giving it a shot. Nice color scheme and I like the logo.
Do you know if bitmesh is the only exchange to support this address type?
Thanks.
Edit: NM I think I figured it out. So if I want to withdraw from another exchange to this wallet, I just use my IP followed by /address. Going to experiment a little.
Edit 2: Ahhhh, I see, you just use the bitcoin like address, that’s it! Very easy. The instructions are pretty good on the website, but not perfectly clear.
I’m having issues with the address type when trying to send from wallet713 to GrinPurse. Does GrinPurse not use grinbox?
Having a hard time finding out how to move coins between wallets that use different address types. Would have expected grinpurse to use grinbox but it’s not a valid address type apparently.
@hamiltino if you use grinbox you expose your IP to the relay you connect to. You could either choose to run your own relay, or you can use the one we provide you with. We don’t collect any data by design, and do our best to avoid accidental data collection, but you have to trust us on that. If you don’t want us to know your IP, you can connect via VPN or possibly through TOR or similar, but not sure how well that works.
Any relay will have access to metadata (such as time and grinbox addresses used in transactions using their relay). A motivated adversary might be able to use this metadata to probabilistically link a grinbox address or IP to specific outputs on the chain.
