I purpose an experiment to test the results of mining solo vs. as a part of a pool.
The experiment is simple should happen like this:
For x amount of time, have some (who have the same rig) mine with a pool and some mine solo; then, compare the results in terms of number of grin mined. The experiment should take place during the same window of time to ensure the network variables correlate (ar_scale and difficulty).
If you want to take part in this experiment, let me know.
Round 1
Time period: January 20th - February 4th (21:45 UTC) Rig: A single Nvidia 2080 Ti mining with cuckatoo_mean_cuda_rtx_31
What algorithm? What’s your rig consist of? @tromp said at current network conditions, expected time to get a c31 block solo mining with a 2080 Ti is 15 days.
I3 4gb ram system with Two 1070ti and one 2080 ti. Two 1070 were mining c29. The 2080 ti was mining cuckatoo_mean_cuda_rtx_31 i was seeing 1 reject so worried it wasnt working but switch to pool i can aleast say it works now. But where 15 days coming from to dont see where trump says this but Interested.
Thank you
