For those who did not follow GrinCon, here is the announcement that with some hard & software effort (using 120 RX 580 mining slightly over a day on an experimental C32 solver for 8G) we found two Cuckatoo-32 blocks on the Grin main chain. Here they are:
I recently published my miner for 8G AMDs in experimental status - sadly atm no Nvidia support. Well in case the cuda miners do not do a release till mid January I will consider a cuda port as well - but more likely ports of them will come
Yea, in total we have some now … afaik that was number 6 or 7 on C32 (and the first that was not by lolMiner)
Good to see the train slowly starts
@CloudMiner: what cards are you running and how do they perform on C32? The screen more looks like first C31 then switch to C32? (Unless that are 2080ti )
No its not lolminer but hey You were the first to experiment and release a c32 miner and I did use it bit noticed it worked better for amd cards but never the less Love ur Work… No not 2080ti… But il show you rather what cards…
