Today I’d like to share my own struggling experience to build my HTTPS Grin wallet with certified encrypted SSL certificate.
Preprequisites:
Assume that you are running a Grin node and Grin wallet listening on port 3415 in Ubuntu . And your HTTP wallet could receive Grin well from other wallets.
—This part is to help new users to run Grin node & wallet with least efforts—
Build a server for Grin node in Google Cloud
After you finish to register an account for Cloud service, please click on the link to get Cloud Shell: Cloud Shell | Google Cloud, click on ‘Launch Cloud Shell’.
Enter following command, or copy and paste (Control +Shift + V)
gcloud beta compute instances create grin-gg1 --zone=us-central1-b --machine-type=f1-micro --tags=grin-gg --image=ubuntu-1804-bionic-v20190530 --image-project=ubuntu-os-cloud --boot-disk-size=30GB --boot-disk-type=pd-standard --boot-disk-device-name=grin-disk1
You can switch 3 free zone locations:
- 1 non-preemptible f1-micro VM instance per month in one of the following US regions:
- Oregon: us-west1
- Iowa: us-central1
- South Carolina: us-east1
And you could change the OS image like Debian-9 which you want by command in cloud shell:
gcloud beta compute images list
You have just created a new Cloud Compute Instances named grin-gg1. Click on SSH button you will be able to open the terminal
Prepare the server for Grin node installation
Enter following command to update and install some tools, you will have to enter the ‘Y’ to confirm the steps
sudo apt-get update; sudo apt-get install git nano tmux pkg-config; sudo apt-get install clang cmake libncurses5-dev libncursesw5-dev zlib1g-dev libssl-dev
Install rust:
curl https://sh.rustup.rs -sSf | sh; source $HOME/.cargo/env
Enter ‘1’ for default installation.
Clone grin and build a release version
git clone https://github.com/mimblewimble/grin.git
cd grin
cargo build --release
The process could take an hour, so you could open second terminal to download Grin node and Grin wallet.
- Grin node: Releases · mimblewimble/grin · GitHub
- Grin wallet: Releases · mimblewimble/grin-wallet · GitHub
We will use wget to download those files in home directory
cd ~
wget https://github.com/mimblewimble/grin/releases/download/v3.1.0/grin-v3.1.0-linux-amd64.tar.gz
wget https://github.com/mimblewimble/grin-wallet/releases/download/v3.1.1/grin-wallet-v3.1.1-linux-amd64.tar.gz
tar -xvf grin-v3.1.0-linux-amd64.tar.gz
tar -xvf grin-wallet-v3.1.1-linux-amd64.tar.gz
We will use command tmux to open 3 sessions, one session is for Grin node running in background, second terminal is for Grin wallet to run in background to listening the port to receive Grin from other people. The third one is for doing some other commands.
tmux new -s grinrun
tmux new -s walletlisten
tmux new -s commands
In tmux GUI, you could use keyboard combination
- Control+b-s to list sessions
- Control+b-d to detach the session to normal bash GUI
tmux attach -t : to open the session you want
Start to run Grin node mainnet, in session named grinrun:
tmux new -s grinrun
cd ~
cd grin/
./grin
Start Grin Wallet to listen the port:
cd ~
cd grin-wallet/
./grin-wallet init ***#Enter your own password, remember to backup the seed (recovery phrase)!***
./grin-wallet -e listen
Change the configuration of Grin node and Grin wallet:
cd ~
cd .grin/main
Change Grin node configuration:
nano grin-server.toml
Change the entry to api_http_addr = “0.0.0.0:3413”
Change Grin Wallet configuration:
nano ~/grin-wallet/grin-wallet.toml
Change the entry to api_listen_interface = “0.0.0.0”
After changing the configuration, restart the Grin node and Grin wallet listening in tmux sessions.
Allow Grin node and Grin wallet ports open to the internet
Go to Google Shell, copy following commands and paste (Contrl+Shift+V)
gcloud compute firewall-rules create main-wallet-port -direction=INGRESS -action=ALLOW -rules=tcp:3415 -target-tags=grin-gg
gcloud compute firewall-rules create main-api-port -direction=INGRESS -action=ALLOW -rules=tcp:3413 -target-tags=grin-gg
gcloud compute firewall-rules create main-p2p-port -direction=INGRESS -action=ALLOW -rules=tcp:3414 -target-tags=grin-gg
gcloud compute firewall-rules create floo-wallet-port -direction=INGRESS -action=ALLOW -rules=tcp:13415 -target-tags=grin-gg
Or you could manually create firewall rules by user graphic in webpage:
Check the current ports open in your server, use command below:
netstat -na|grep 0.0.0.0
The output will look like:
tcp 0 0 0.0.0.0:3413 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:3414 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:3415 0.0.0.0:* LISTEN
Now your ports are open and will be able to accessed by people around the world, and your wallet is accepting $GRIN like http://your_ip_address:3415
—End of Grin node & wallet installation part—
Technical Idea
I’m just a newbie, maybe I do not explain well but hope it helps someone new in this system administration. Expert! please comment/or correct if what I explained is wrong. Thanks in advance.
HTTP GRIN wallet:
- Your GRIN wallet listening port 3415 <———> protocol HTTP <———> Internet wallets
HTTPs GRIN wallet:
- Your GRIN wallet listening port 3415 <———> SSL Proxy by Apache <———> protocol HTTPs <———> Internet wallets
So for HTTPS, we have to install Reverse Proxy for SSL service, we could use self-signed certificate but not recommend. We could use certified Let’s Encrypt certificate for free.
Install Apache and Mods
sudo apt-get install apache2
sudo a2enmod proxy
sudo a2enmod proxy_http
sudo a2enmod proxy_balancer
sudo a2enmod lbmethod_byrequests
sudo systemctl restart apache2
Whitelist the ports in your server
sudo ufw allow http
sudo ufw allow https
sudo ufw allow proto tcp from any to any port 3413,3414,3415
Allow ports in Amazon AWS
Identify the Security group associated with your node, edit the firewall rule in Amazon EC2
Install certified SSL with Let’s Encrypt
sudo wget https://dl.eff.org/certbot-auto -O /usr/sbin/certbot-auto
sudo chmod a+x /usr/sbin/certbot-auto
sudo certbot-auto --apache -d grin.yourdomain.com
Change the Apache Configuration
mkdir -p /etc/apache2/log/
sudo nano /etc/apache2/sites-available/000-default-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
ServerName grin.yourdomain.com
ServerAdmin your_email@email.com
DocumentRoot /var/www/html
<Directory /var/www/html>
Options FollowSymLinks
AllowOverride All
Allow from all
</Directory>
LogLevel notice
ErrorLog /etc/apache2/log/grin-error.log
CustomLog /etc/apache2/log/grin-access.log combined
SSLEngine on
SSLStrictSNIVHostCheck On
SSLCipherSuite ECDH+AESGCM,DH+AESGCM,ECDH+AES256,DH+AES256,ECDH+AES128,DH+AES,ECDH+3DES,DH+3DES,RSA+AESGCM,RSA+AES,RSA+3DES,!aNULL,!MD5,!DSS
SSLHonorCipherOrder on
SSLProtocol all -SSLv2 -SSLv3
<FilesMatch “\.(cgi|shtml|phtml|php)$”>
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
BrowserMatch “MSIE [2-6]” nokeepalive ssl-unclean-shutdown downgrade-1.0 force-response-1.0
BrowserMatch “MSIE [17-9]” ssl-unclean-shutdown
SSLCertificateFile /etc/letsencrypt/live/grin.yourdomain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/grin.yourdomain.com/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
SSLProxyEngine On
ProxyPreserveHost On
ProxyPass / http://127.0.0.1:3415/
ProxyPassReverse / http://127.0.0.1:3415/
</VirtualHost>
</IfModule>
Remember the “/” at the end of the port 3415, otherwise you will have following error in grin-error.log
[Fri Jun 10 17:32:48.244509 2019] [proxy:error] [pid 12212:tid 140660153763584] [client <source_ip_wallet>:56442] AH00898: DNS lookup failure for: 127.0.0.1:3415v1 returned by /v1/wallet/foreign/receive_tx
And grin-access.log will show return code HTTP 502
<source_ip_wallet> - - [10/Jun/2019:17:32:48 +0000] “POST /v1/wallet/foreign/receive_tx HTTP/1.1” 502 3954 “-” “grin-client”
Restart Apache Service:
Auto review SSL Certificate:
crontab -e
0 2 * * * sudo /usr/sbin/certbot-auto -q renew
Testing your HTTPs Grin Wallet
Now your HTTPs wallet should be like: https ://grin.yourdomain.com (without port) because your HTTPs listening to port 443 by default, when GRIN sent to your wallet, it redirects to http://127.0.0.1:3415/ as your wallet listening.
Here is my test in my own server:
(In source wallet I will send 0.1 GRIN to https://grin.anonymous.cash)
Sender will be charged default fee 0.008 GRIN
(In target wallet we should see the Shared Transaction Id as same as source wallet)
There will be no error message in grin-error.log, and grin-access.log will show return code HTTP 200 as below:
<source_ip_wallet> - - [11/Jun/2019:01:02:32 +0000] "POST /v1/wallet/foreign/receive_tx HTTP/1.1" **200** 10263 "-" "grin-client"
Test to withdraw GRIN from the crypto exchange Poloniex.com
( DON’T FORGET: Only send 0.1 Grin to test your https wallet first, then send big amount)
