Sending grin, always in sending state
The grin I sent yesterday has been in this state for over 24 hours now. Will my coin be lost? What should I do now?
The node cannot be reached as the error states. Did you:
  1. Check internet connection, update to latest version of Ironbelly
  2. If you run your own bode as backend for ironbelly, check that node
  3. Contact @i1skn on the Tlegram iron belly support channel
    Telegram: Contact @ironbelly
Hope you get it fixed soon
