Dear Grin Community,
Today, I come before you with a heavy heart to share a significant decision regarding the future of Ironbelly. After much deliberation and hours of thought, I have made the difficult decision to discontinue the development and support of the Ironbelly project. This was not an easy decision to make, especially considering the passion and effort we’ve all invested in Ironbelly over the years. However, I believe it is the right decision for me at this time.
There are several reasons behind this decision, and I want to be transparent about them:
- Complex Technical Stack: Ironbelly’s technical stack, which includes TOR on mobile, the grin-wallet rust codebase on mobile, and react native, is quite complex. This complexity has made it increasingly challenging to maintain and update the app, requiring a significant amount of time and resources.
- Low Usage: Despite our efforts, Ironbelly has seen relatively low usage, with approximately 150 downloads combined across iOS and Android per month over the last year. This level of engagement has made it difficult to justify the continued investment in the project.
- TOR Stability Issues: Using TOR for addresses has introduced a level of instability, leading to user complaints and dissatisfaction. Ensuring a stable and reliable user experience on mobile devices has been a challenge due to these issues.
- Legal aspect: The situation regarding the legality of privacy coins changes continuously across different jurisdictions. The app on iOS or Android app stores is tight to me as a developer. It’s rather overwhelming to monitor all of these.
- My personal shift of priorities: The truth is that I also no longer as passionate about Grin as I once was.
Given these challenges, I have decided that it is time to wind down the project.
Here are the key dates and actions you need to be aware of
- 8th April 2024 - The Ironbely Grin node will be stopped: I will be stopping the Ironbelly Grin node. However, you can continue to use https://grinnode.live/ or any other Grin node. Just change it inside the app.
- 8th April 2024 - Removal from iOS and Android app stores: Concurrently with the node shutdown, the Ironbelly app will be removed from both the iOS and Android app stores.
- APK file: Latest APK file is accessible here - Releases · i1skn/ironbelly · GitHub.
I want to assure you that this decision was not made lightly. Ironbelly has been a lot of fun to work on, and it saddens me to see it come to an end. However, I believe it is the best course of action under the circumstances.
For the Future
- Open Source Code: The code for Ironbelly will remain open and available. Should anyone wish to pick up the development, I encourage you to do so. However, I ask that you use a different name, logo, and branding for the project. This is to ensure that users are aware they are engaging with a project that is distinct from Ironbelly. This is already required by Irobelly license, just want to re-iterate it here.
FAQ
What happens to my funds? Literally nothing. Your funds are tight to your 24 words, not Ironbelly. You can:
- Stay: Continue using Ironbely at your own risk using any other trusted Grin node (like https://grinnode.live/, but DYOR)
- Move to another wallet: Take your 24 words and restore your wallet using any other Grin wallet (Grin)
Import new wallet after 8th April. The app will show initially a network error, then you should change the node inside the settings and then click on “Repair Wallet”.
I want to extend my deepest gratitude to everyone who has supported, used, and believed in Ironbelly. Your enthusiasm and feedback have been the driving force behind the project, and I am truly grateful for the community that has built up around Ironbelly.
Though this chapter is closing, I am hopeful for the future and excited to see what new projects and innovations will emerge from this incredible community.
Thank you for your understanding and support.
Warm regards,
Ivan Sorokin
Creator of Ironbelly
