After being the first to market with the SAPPHIRE RX 570 16GB HDMI Blockchain Graphics Card specially designed for the GRIN Community. SAPPHIRE is first again with the only Grin solution that will support Cuckatoo 32 protocol as a result of the recent update to the ePIC Boost Miner software and in preparation for Grin migrating to C32 in January 2020.
I have my rig up and running but I’m having a strange issue when installing the AMD drivers. The system boots and reboots perfectly until I install AMDGPU-PRO drivers, then it boots to the black diagnostic screen and never gets past it. It happens every time and I’ve reinstalled Ubuntu 4 times in a row to test this and the same thing happens every time. Drivers cause the system to hang during the boot. Please let me know if you have any suggestions or advice! Thanks.
Thanks for the suggestion. I will try that tomorrow on a fresh Ubuntu install. I know my board supports atomics but I don’t think that my CPU does, it’s a Pentium. Couldn’t find a an 8th generation intel mobo and also couldn’t find any 7th generation intel cores so I ended up tearing apart an old HP for the Pentium chip. Lol.
The Vega 64 would mine C31 well, but its power draw is way higher than the RX 570 16GB, and it costs more too. The RX 570 16GB is the much more cost-effective option.
The problem with the vega 64 is outside some very specific cards the memory is only 8 GB and you want to larger memory buffer for effective C31 mining.
You are right the Sapphire RX 570 16GB card is a very cost effective solutions for C31 mining.
There’s the Frontier Edition (which I have as well) that is great for C29 and would be great for C31, but then you’re pulling big Watts and the card will likely throttle after a while.
The thing with these 16GB cards is that it’s a waste to be mining just C29 with them, when we could be using more RAM to mine C31!
I’ve seen miners under development by the community, but no updates yet…
What hash rate are you getting? The thing is, the FE was a $1,000 card, and the RX 570 16GB is much cheaper, with robust cooling so you can leave it running 24/7. I was getting 165W or even more from my FE but the return with C29 just wasn’t worth it. The RX 570 16GB makes much more sense for pure mining.
