Hi, I tried to withdraw my grins to my wallet with the help of grin documentation and listening wallet. I also tried hedwig and niffler wallet. Every withdrawal ended up with an error.
Fortunately, my grins aren’t lost. They will be refunded. However, I can’t withdraw from the exchange. They haven’t got another withdrawal option.
Has anyone come across these issues? How to solve them?
I’m on Linux. The transaction was unsuccessful even with my firewall disabled.
I have changed my toml file according to the documentation (basically allowing wallet to listen on 0.0.0.0). I start my grin node and then grin wallet with listen command.
In Poloniex, I set the receiver’s address as http://<ip>. I also tried http://<ip>:3415. Both failed. The latter is imo wrong, because writing http:// already implies port 80.
I would then argue that the new documentation is not complete. It doesn’t contain sending coins via http and via file.
TradeOgre is doing transactions via JSON file! Because of that “outdated” documentation I was able to accept coins from TradeOgre instead of having my coins stuck.
It was a purposeful decision not to include http and file transactions, as they become useless in 3 months and we don’t have some college intern to rewrite everything. But yes, you’re right, I forgot about it.
By the way I’m not sure how come Grin++ and Niffler both didn’t work. Sounds very odd, maybe you could specify more.
But know that if in the near future you wish to withdraw again using http, I suggest Grin++, it seems to work more often. Just make sure the delete everything NIffler related first.
I have another problem. Grin++ needs to connect to my local node? Niffler couldn’t connect to my local node, so I used remote. Now it looks like Grin++ can’t connect to my local node either and can’t use remote.
Grin++ says: STATUS: Waiting for Peers
EDIT: Ok, now my Grin++ is connected to remote peers. However, I’d still like to use my local node. But I’ll manage for now.
Grin++ is it self is a full node (a different implementation of it). You shouldn’t have a “regular” local node with it, nor connect it to a remote node.
