iPollo G1 Mini : is it possible to start/stop the miner using an API call?
Otherwise is it reasonable to start/stop the ASIC using a remote controlled electrical outlet?
Will it support being turned on/off several times a day?
A friend of mine is planning to mine Grin using solar panels, so will need to be able to start/stop them depending on the sunshine outside.
Thanks for your help.
Using a network PDU is something to consider.
e.g.
There are cheaper versions available, but I trust the APC hardware for electricity.
The miner itself should have no problem, turning on/off couple times a day.
At least the G1-Minis have no problems, I did not test it with the G1.
