I am using grin-miner 1.0.2, on ubuntu 18.04.1, mining with 4x nvidia gtx 1070 ti’s.
At the wall power consumption is fluctuating every second or so between 650w and 730w (that’s a little much right?) grin-miner shows a steady mining rate, however nvidia-smi also matches the wall power consumption displaying rapidly fluctuating power consumption, a screenshot of nvida-smi is shown below (in the capture instance, you can see the top 2 gpu’s running at only ~60w, a second later they will show back to 140w and back again, all 4 gpu’s are showing this behavior) any ideas what is going on?
EDIT: I forgot to mention that on top of this, occasionally (perhaps once an hour) the miners will drop down to 10w usage for about a minute, fans turn off, wall power goes to ~100w all the while grin-miner displays normal operation. Another mystery.
