Hi everybody,
Looking for a C32 mining calculator. Does one exist?
Hi everybody,
There is solo mining calculator hope it will help a bit https://2cryptocalc.com/grin32-mining-calculator?hashrate=1 (you can replace last number 1 with GPS you want to calculate) and yes this one you can check for different GPU’s https://2cryptocalc.com/
And right now https://grin.2miners.com/en are only pool supporting C32 while btc.com accepts C32 but listed as C31.
Thanks, I’ll have a look, seems perfect
Grinmint also supports C32 but labeled as C31
Yes I too heard but could not find anywhere in their website mentioned. And in mining Pool stats only pool having C32 hashrate 2miners.
