Are there any specific instructions for grin + + wallet? My wallet is showing up all the time
@grin001 If on Windows, you can try going to firewall settings, open Port 3414 for TCP for incoming and outgoing traffic (only one of those is needed, but I forgot which one, I think it was outgoing).
Not seeing any incoming peers is not an issue.
Use this link to check if your port 3414vis open:
https://canyouseeme.org/
O. and wait till you are synced which should maximally take a few minutes.
Here you can find support Telegram: Contact @GrinPP
